Info: Allison trans in 2.6 truck
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I currently building a 2.6 pulling truck and was planning on running an Allison tranny, but have been told by few that it will not hold up. Wondering who's using a Allison in a pulling truck in the 1000hp and up application. Seems most people switch to a ZF6 tranny at these power levels. Any info or experience's would be greatly appreciated.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
It def will hold up. The zf-6 or nv4500 would be a better option in my opinion. You can leave the line with more Rpms. Call the guys at leadfoot, there black 2.6 truck is a standard and it flat out runs.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I have a Suncoast stage 5 with billet shafts and also one with Suncoast stage 4 kit in it and stock shafts. I was going to run the stage 5 and keep the other for a back up.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Trade or sell one of those so you can get a standard.
greendury
Jan 28, 2011
130
I agree don't shift but why not run 1:1 4th gear and have less power loss through the transmission. 4th with a 4:56 r/p is what I ran.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I am going to run 3:42 gears and 3rd.
3:42's and 3rd put's you in between 4:56 and 4:88 in 4th. I heard that 3:42 ring and pinion's hold up better than 4:56 because of more tooth contact area.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Put 3.42 gears in it and don't shift, start in third and run third, it will hold great...
Yeah I've actually heard a stock trans will hold awesome just like that. I'm not sure what Matt sparkman makes power wise, he's the only auto 2.6 truck around my area. He won points this year a strong truck. Maybe talk to him or fleece as they have a strong influence in that truck I believe.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
3.42's ain't enough for around here. Not sure bout MN. If you're actually making four digits, need to spin em harder than 3.42 will.
A 3.42 ring and pinion are physically the strongest set you can put in an AAM. The size but more importantly the gear mesh. They will hold so well that while others are swapping r & p every few hooks, you are still going strong. The problem with this is it moves the driveline strain further along to the next weak point. Normally the pinion shears in half and the ring gear sends it down through the case, which is not repairable. Junks the entire housing, along with r & p. At his point, I would rather inspect and/or replace ring/pinion every little bit instead. Plus, like i said, 3.42s arent fast enough unless you're sticking to brush pulls. Welcome to 2.6! SMH repeatedly
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
The allison will like life a little better sticking to 3rd gear only, though. Get a good lock-up box and with a properly setup trans build, you can light same turbine and housing sizes as a stick truck. Come off line slinging 'em, too.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Would you share what set up your running?
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
3.42s for 3 years straight. 2 junked housings to show for it over 60 hooks. Compared to everyone else's crates of cracked, chipped, etc r & p. Pick your poison. There will never be 3.42s back in this truck. 35's.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Do you agree you cant get the same amount of rpms off the line with an allison as you can with a standard. Or are you saying its a wash, Interested to hear your opinion sir.
