Build it or take it easy on the 4-5 shift and 5-4 shift. fill out your signature with your truck and what's done to it. You limped the trans btw
C3 clutch slipping on the 4-5 shift,, What tuner/programer are you using?
5 speeds won't hold as much as the 6 speeds in stock form. I know of few guys with 6 speeds that ran a lot of power through them stock and never limped. When tore down the clutches were junk and steels warped but never limped.I don't understand how this is happening to people. I have run some very large tunes McRat's race tune being the biggest, with a completely stock allison 6 speed and only limped one time. But then again I lift for the higher shifts let it shirt and roll back into it.
I was cooking down the road, passing some cars. Transmission slammed into 3rd gear and the check engine light came on. It gave me a P0700 code, how do I fix that?
I had the same issue it was the start of a PIA
Seen that to did ya :rofl:
