Gmax kit with a 1056 is gonna cost you almost $3k alone. Add fluid and a deep pan and your @$32-3400 depending on which deep pan you go with. Not to mention when the tcase comes out it is right prime time to put a pump rub kit in it. Add another $250 for that. $1000 labor and you might as well call it $4700 out the door done with the pump rub kit. then you gotta get it retuned to get rid of defuel and make the most of your newly built mountain mover and thats gonna cost you a couple hundred if you go back to your original tuner who already has your license. You better count on $5k to get that job done! When you push the panty dropper to the floor though and you smoke the coyote 5.0 sitting next to you at the stop light youll be glad you dropped $5k on it!:thumb:
