All wheel drive duramax
minisub
6-5/6-6;Whatever It Takes
Sep 11, 2006
474
Cleveland, OH
They are BFG all terrain TA's
I will never buy another set again for this truck the Yokohama's I had were way better
In my experience (3 sets) I have noticed a funny thing about the BFGs. When they look totally fine with at least 10K miles left on them, they turn into ice skates....:eek:
610
Anyone have a H1 Alpha those are AWD and have the Allison Duh
this is the only t-case that is fully AWD it has a mechanical open diff
NP 203 is the same were on 1/2-1ton trucks
the HMMWV ran a mag nesium case both behind the th400 and 4l80E
H1A run a New Venture Gear 242 tcase... part is a hummer dealer specific part number.. got it sumewere
one o fhte many ideas i have to convert my truck to 4wd/AWD
on the side note need to manully lock hte front diff actuator to keep the front fully engaged
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
as for the awd thing and street traction thing, Id much rather just have stabilitrak on my truck (like the 09+ dmax's) than awd.
KEVINL
1,431
Phoenix, AZ
Stabilitrack is just a nanny to keep you from crashing
I shut it off everytime I get in the G8
I just want more traction I raced an Srt-4 the other day and I just spun I know I would have won if I could of got the power down.
My truck hates being in 4wd other than in a straight line. When I go to the track I wait till I'm staged to put it in 4wd. If I do it before I turn out I can feel it binding and it doesn't feel happy
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
Stock? ? ? ?Or highly modified? . . . ? ??
Tune only Dmaxes are any where from 850-1150 or so. No problem making 1400 RWTQ with a Dmax.
Hard to beleive after all your work with gassers huh? Ive been there.:)
fast03
1,201
61
Rancho Cucamonga
I don't know why, but I don't get the wheel spin on a rolling acceleration like some others do. I run traction bars and have 33 bfg at's. Maybe its my torque converter or the traction bars that keep it from doing it, but all I will get is a bit of spin on the shift 1-2 or 2-3 that is theoretically 525-550 hp( have not dynoed or run the track since the new turbo)
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Dads escalade is AWD and I think it is the dumbest thing ever, his MPG is awful, his handleing in slippery terrain is crap, and it's loud as hell inside at city speed. I guess I don't know what is so hard about reaching over and hitting 4Hi on the dash???
And I don't know to many people on here that have less than 1000ft lbs of tq in there truck??? 1051ft lbs here and I'm just a stock tranny'd puss
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
you can get 1200-ish ft lbs at the crank with just a tune only, completely stock engine.
Now put a bigger turbo on, injectors, dual CP3's etc on top of that. :)
I bet with a really good boosted 4wd launch (remember the allison has a pretty deep 1st gear ratio) you could break one of those cases stock or with a small tow tune. Its the torque at low rpm that breaks these things.
Zeake
Dec 2, 2009
24
1200 at the crank with tune only. . . . . .Really. .. . . How long will the allison hold that.? . . . . . .Not long I am betting. I knew there was a good reason I was looking at buying a Duramax. . . .Drove an 05 today. Told the dealer I only wanted heated seats and an 06 ccsb. I can't wait. :thumb:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
nope! Not long at all. :)
Once you build the transmission you are good to go.
You can run high 12's in a 7,000lb crew cab with a completely stock engine, tune only. Just build the trans, brace the front steering, put a lift pump on, cheap exhaust, and some gauges...
ben
Fingers
Village Idiot
1,717
96
White Oak, PA
I personally would like the AWD with the open transfer case differential. Primarily for towing. By the time the tires slip in 2WD it is too late to push the 4wd button and I hate going in and out of 4wd. Especially when the pavement is wet. I always seem to be lighting up the rear end when its wet towing or not.
