Question: Aftermarket Intercooler?
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Alright I have a built motor with a custom 2.6 charger for truck pulling and am still runing a stock intercooler. I understand the benifits like more air and lower boost pressure but what else can I exspect? I know I should be going air to water but it is still a street driven truck and will stay that way unless you want to supply me with a tow rig and trailer.
Harbin_22
3,858
7
Southern Indiana
When I put mine in, I was on 500hp stock turbo/injector tuning. EGT's dropped some overall. Seemed liked they climbed slower too. Other then that, not much difference.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
even after swapping out my leaky stocker for a banks i saw no egt drop, no change in boost, etc except i didnt have $ 750 in my wallet anymore:rofl:
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
It should help just a little, not worth it for a street truck but when you are running a class might be worth it....
If weight isn't an issue I still think you could run air to water, just run a radiator somewhere. Can also have it run into a cooling tank but only run ice when you are pulling
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
My LB7 came with a banks intercooler installed :woott: Seen 65psi a few times, but I honestly dont even know if it helps unless im pulling a big load, which my truck doesnt anymore.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
I was thinking of some how fabbing up an ice box around the intercooler pipe for when I pull. That way I am getting the benifit of cold air but not having to deal with no being able to street drive it.
Otherwise try to put ice somewhere around the intercooler.
ikeG
Oughta Know Better
Apr 19, 2011
2,465
147
Western PA
www.facebook.com
We have a used Banks on our 2.6 truck for now, switching to a2w this winter. Came from a 2.6 truck as well. Banks have cast end tanks, no welds weld to blow!
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
Oh yea I beat my banks all the time, 75 PSI all the time
And maybe look at adding in a small atw with the banks? if you really want the added cooling you could do that and just not turn it on unless you were pulling
