Hey guys been searching, we put a socal 9100af in a lly. What's the easiest way to swap injector wiring. Can it be done at the ficm? Thanks for any help guys!
will call you tomorrow, thank you sir!Yes you change the wiring at the ficm, I have the info at work. Give me a call or call Guy@SoCal and we will get you taken care of!:hug:
Has to be done at the ficm or it will set codes. Tried at the ecm first cause it was easier but the ficm is only way to do it without issues.
Will this set codes like P1223 and P1232 Fuel injector open circuit? Causes a rough idle.
Mine was swithed at the bale connector with a kit I bought. Thanks.
Some tuners can change the firing order in your tune also.
Wait...if it was switched at the bale connectors, then that would be changing the injector control circuit wires...which Mark said will set codes. Who did you buy the kit from? Did they know you have an LB7/LLY???
Some tuners can change the firing order in your tune also. Idk what they charge but theres a few that can do this if you send them your tune.
I would think it would be safer to actually change the wiring though, if you retuned and the AF cam was forgotten to take into account, some serious/expensive issues would arise.
Yep just saying it was an option but if you have it reqired and "forget" about the AF cam wouldn't that be the same? lol.
Chances of rewiring as opposed to re-tuning are drastically different!
