I know so little about EFILive its just not funny. To that end, Id like to ask you guys to look at the following four tables, and give me your opinions about what would happen if this tune was run at the strip.
the only thing I would change is the lower left hand side of the PW Table I would imagine that smokes like crazy. But maybe for the track it wouldnt matter since thats more in the lower rpm's and depending on what the actual timing table looks like thats kinda high timing
You wanna bet? Seriously, which table is it? This is not a tune being sold to the public, so I have no issue whatsoever posting the info.Being thats the maximum timming allowed, without seeing the actual timing table it's hard to tell where it's really at. I don't exspect Tom to post the actual table though.
I wouldn't run it unless you want to damage your engine. There is too much timing way to soon. The amount of fuel that low would not be an advantage either. The reason EFI live is so successful is the ability to get all the right things in all the right places.
the truck shifted at 3250rpm, if that matters.
I wish i understood how these tables all work together. One timing table works here, another works here, this works there, etc....
Just so you know, these are tables are from the tune i now call the "lb7rodbender", and your opinions pretty much mirror what ive come to figure out. It was much more extreme than my normal dmaxtuner "12.40" tune and i didnt know about it.
which table would that be? I can look it up.
Im just curious and wanted some pros to give me their opinion. Thanks.
well at 2800 rpms. If you can hold 160mpa with a 3034us pulewidth (assuming pilot is off)
ur 27.4 degres of timing will put about 53% of the injector pulse before tdc on paper.
Personally i have ran tunes before with simmilar demands
