What I would like to know is a timing table that is pretty agressive in the lower rpm at higher elevation at least over 5000 feet that may be ok with no detrimental effects to rods going to be a rod killer at sea level? Does the lack of air/oxygen/less boost make a motor more tollerable for more timing? Another thing fuel economy tunes run higher timing at little to no boost so as we start adding some boost should we be a little more conservative on the timing?
Here is some things I've learned from others that have been nice enough to make some of it public.
We want peak cylinder pressure around 10 degree's ATDC if I remember correctly , splitting it 50/50 or 60/40 might be close :dontknow:
Higher timing=better economy, slow's turbo spoolup, more power, less smoke, cooler egts, higher cylinder pressure, increased engine wear, increased engine noise
Low timing= Lazyness, smoky, high egt's, faster spoolup, bad economy, longer engine life, lower cylinder pressure, basically opposit from above
