Help: A member is broke down Silverton CO area
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Russ Cocker (Cocker 6236) is broke down just outside of Silverton Colorado and members out that way can lend a hand? He is between Durango and Silverton possible stuck t stats or water pump,the truck is over heating.Any help is appreciated.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Ok just spoke with anoter member Wes Smith and he said he smoked 2 water pumps after his twins same symtoms blowing coolant out the over flow and it had a grinding noise at idle.Russ's water pump has 165,000 on it and never been changed, pretty sure the twins were the death of it i bet.
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
I hope its something as simple as a water pump, and wish i was closer to lend a hand. :( Good luck (Cocker 6236) :thumb:
Mile_high
The Mad Hatter
Oct 31, 2009
702
Denver, Colorado
Montrose is only like 30 miles away and they will have several parts stores there if he can limp it up there.
It's downhill most of that drive... couple thousand feet lower
13,712
773
I just got off the phone with Russell. He made it to where he is staying for the night. After talking to him, I think the water pump and head gaskets are both ok. I think he needs a new cap for his coolant tank though. It isn't holding pressure, and I think it is letting the coolant boil when it gets a little hotter going up grades.
13,712
773
It's some sort of tank he got with his twins. It isn't stock. I have no idea what it came off of.
