99-02 aftermarket foglamp replacement
496 BB
Head Thread De-Railer
Feb 20, 2009
697
5
At your girlfriends house
If your like me and have these model year of truck Im sure your hating your stupid fog lamps that are no brighter than your kids nightlight and leak a TON of moisture. Also if you install any kind of aftermarket bulb with higher wattage they charcoal the housings in as little as 2 months. I was on my 3rd set and same thing happened so I got sick of it and starting researching what sizes and how the lamps were made. I finally got around to ordering the Hella FF75 kit from summit racing ($125 shipped). Upon inspection I am pleased with the construction of the lamps themselves. Ive had a set on a '97 4Runner since it was new with only replacing a lens once so I know the quality is there.
The one thing I wanted was to install the new lamps on the OEM bracketry as I HATE seeing cars roll down the road with their foglights bouncing all over the place looking like they are flickering from not having a secure mounting spot. So here it was I did. It was all from what was included in the package from Hella and from the OEM stuff I took off.
Needed:
Grinder with metal cutoff wheel
Screwdrivers (both phillips and straight)
Sharpie
Pliers and crimpers
Knife (utility)
Hammer
3+ hours of your time (alot of test fitting involved if you are meticulous)
So first start off by removing the OEM foglights and unplug the proper connections. They are held on by (2) 10mm bolts up on the lower part of the bumper. Its easier to use the 1/4" drive as it fits better in there. Here it what you should have with one off and the new ones....
Now on the factory brackets remove the (2) trim screws that hold the actual lamp housing on to the bracket and unscrew the adjuster wing nut at the bottom....
Here it what you are left with....
Here is the Hella bracket that came with the lights...
This first light was the passenger side (for reference). I then cut the Hella bracket on the left side a little past the point where it comes across the top. After that I used a hammer to flatten it out so its pointing straight up....
At this point you should attach the Hella bracket to the lamp and install the OEM bracket in the truck for fitment. Once its bolted in take a sharpie and shim up your light to where its on center in the opening and where you want it left to right and mark on the straight cut bracket where it meets the OEM tab and hole. Take the bracket back out and drill a hole in the Hella bracket that matches with your mark. I used #8 screws and hardware for mock up but then switched out to 1/4" bolts with lock washers and teethed washers on the inside so it doesnt move.
For the other side I again bolted in the bracket but this time with the one side already attached to the OEM bracket and the other side attached with the remainder of the Hella bracket coming straight across. Once its in you can again shim up your light to your likings and mark where you want to make a 90* bend in the Hella bracket to meet up with the OEM bracket. After its marked take off the whole thing again and make the bend in the bracket you just marked.....
Again drill a hole in the Hella bracket to match up with the hole in the OEM bracket. Install your hardware and bolt it up on the truck again for fitment. I had to enlarge the mounting holes on top of the OEM bracket to get more adjustability out of the whole bracket.
Here is the final product....
After all is good from a fitment standpoint go ahead and wire up the lights inside the housings and adjust when its dusk outside. Make sure to tighten everything back down after adjusting. I havent got my HIDs for these yet as they are on order but thats easy to install. Its an H7 bulb.
Here they are before adjusting....
darkness
1,317
380
vegas
that turned out real good :thumb:. i too did something different with my '04 gmc fogs...i placed some 5" 100 watt off-roaders in the factory spots when i raised my bumber. only thing is i might as well just run the high beams cause they are too bright for the highway :eek::(
SparkZ03DMAX
Nov 16, 2009
866
North Carolina
Wow, I shouldve done that. I JUST got my new set of OEM fog lamps in. I got HIDs for them. By from what you say, all I've got to look forward to is a burnt lamp?
What I did; I siliconed the sh** out of them to keep the lens intact. Then added the HIDs. Looks good right now, but I hope you're not right.
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Hey I really like that look I think I am going to have to do this. I like to drive with just fog lights but they do shake around a lot. Those new fog lights look quite a bit brighter than the factory ones too.
496 BB
Feb 20, 2009
697
5
Yea well shitty thing is the OEMs are only like 27W bulbs. I put 55W in there years ago and they roasted not to long after. I then replaced with 887 (?) bulbs that were only like 37W and they too roasted the insides. I then thought well HIDs burn alot cooler so figured Id give next shot with those....no dice. Its always the same....inside gets moisture in and the heat of the bulbs bake the chrome reflector material inside. They suck IMO. Ive been trying to find time to get these for a year now and finally ordered em last Thursday.
So yea your HIDs will burn them out here shortly too. Also the moisture that gets in there will eventually shorten the life of the HID itself.
I'll post pics up when I get the HIDs in. Im hoping to get em in this coming weekend but we'll see when they get here. Guess I should order those now :eek:
SparkZ03DMAX
Nov 16, 2009
866
North Carolina
Well, I used silicone around the lens in hope of keeping moisture out and keeping the lens intact
496 BB
Feb 20, 2009
697
5
Well got this HIDs in tonight. Easy to do but you have to drill out the hole in tha back of the housing to accommodate the HID wires. thats ok because the housing is not weather tight. The housing inside the housing is though. Still daylight so no pics. Dont want to be like LethalWeapon on DP and show only daytime pics...lol. Hopefull I can get these adjusted tonight also if the beer stop going down so smooth :beer
