943hp 1326lbft!
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
We did before and after dyno runs with same setup with and without valve springs and gained well over 100hp with the springs installed. You guys out there running big boost numbers on stock springs are loosing alot. Josh was seeing 70psi boost on the dyno runs.
Very interesting info... nice that you tested with and without.
Even though as someone mentioned, the turbo(s) have a lot to do with the powerband (rpms) that is still pretty high revs to make peak power with no other head work and stock cam... impressive!
13,765
834
Any difference between Hamilton and other springs out there like SoCal?? Or you think they would all do the same thing? Just curious why you chose them?
Thanks
SoCal springs are a beehive style spring that uses smaller and lighter spring retainers and upgraded spring seats that go down in the head. The Hamilton springs are spring upgrades only and reuse factory hardware. All total you will spend about $80 more for SoCal, but you get a lot more for your money, IMO. I think his sig says why he went with Hamilton.
Iceman56
Jan 19, 2009
867
Madison, SD
Thank you Josh, I wasn't trying to start anything just trying to learn:beer
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Yes Zach sponsored josh's truck. Guy's stuff is great but if people didn't try new things we would all have cookie cutter setups.
02bigstrokin
Sep 9, 2008
882
no problem man, yeah hamilton sponsored my truck with some valvesprings and asked that i do some before and after dyno testing. i did and they worked great. im not saying anything bad about socal springs i just have Hamiltons. they all do the same thing.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
Wow great numbers man! I was almost regretting buying my SoCal heads cause I'm hearing they don't make that much of a difference. Now I feel much better:thumb:
Nick
