Question from a dummy that may or may not help others too:
Let's pick a do-able HP # for a stock displacement motor..... say 750, 800, 850, 900, 1000.... pick your number.
How will a stroked motor compare to a stock displacement motor with regards to stress on engine components?
In other words, if I make an 800 HP in each motor using resonably the same components (turbos, injectors, no nitrous, etc.) which one should I (in theory) expect to last longer? Or is there a difference?
I know there isn't a concrete answer to this as they could both let go at any time. But since the stroker should be running at less of a % of ideal maximum would this translate into anything tangable?
Dumb question?
