5.3 performance???
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
I had a blast with my little 4.8 truck it may have been a high 13 to low 14 truck on a good day and me hitting the shifts. But the noise of that little engine wrapping up tight as a drum is addicting. Next month is the month for a new toy. It will most likely be an ls
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
You guys were right...
I'm sorry...:eek:
I thought fer sure the only difference between the 4.8 and 5.3 was the bore, but it is the stroke that is the (main) difference...
I went back thru my LS build books, notes and the internet and found I was very mistaken, and I'm terribly sorry for posting crap,
I was so sure tho:angel:
http://www.superchevy.com/technical..._4_8l_vs_5_3l_engine_tech_little_ls_slugfest/
I'm an idiot:baby:
Dirtymaxx03
3,109
Not a 5.3 but you get a lot more bang for your buck building a gasser
Roughly 8.2 liters of displacement :woott:
A. Stock Lbz
Aug 13, 2013
342
spokane wa
Yes you do sbc and bbc are cheap compared to diesels. How do ya post pics? Ill show you guys my 383 sbc s475 turbo trans am im building
Dirtymaxx03
3,109
Setup a Photobucket account. Get the app and it makes life way easy. Then you just copy and paste the IMG code.
If I don't turbo this BBC I am building a boosted small block
Big Block 88
Nov 3, 2008
4,665
I'm sorry...:eek:
I'm an idiot:baby:
Not a big deal man, hell im wrong more than im right in the diesel game. I was ticked off by your posts because i was purposely misled by a guy here a couple months ago, and he will not admit he was wrong. Caused me alot of tuning issues on my 4.8 and i went back to stock. Difference is this guy stil swears he wasnt wrong and is doing work for other people i know, and you can swallownyour pride and say you were wrong. All is cool man
Big Block 88
Nov 3, 2008
4,665
How in the hell did you squeez out around 490 cubes? Biggest i have seen is 472ish. ON EDIT: i have heard of race engines around 500 before. But they were block filled race only engine
You know another awsome huge power motor is an 8.1. Buddy of mine is in the 12's with an 8.1 swap in his z71. Nasty bastard for sure, he will be adding boost this season for 11's. You can find them pretty cheap in junk yards and they have become more numerous do to there age now
A. Stock Lbz
Aug 13, 2013
342
spokane wa
<a href="http://s1371.photobucket.com/user/alexstockton86/media/Mobile%20Uploads/20140307_184332_zps98cc5c1f.jpg.html" target="_blank"><img src="http://i1371.photobucket.com/albums/ag289/alexstockton86/Mobile%20Uploads/20140307_184332_zps98cc5c1f.jpg" border="0" alt=" photo 20140307_184332_zps98cc5c1f.jpg"/></a>83 sbc dart 215 platinum iron eagles th400 w/brake
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
How well does the blow through setups work?
A. Stock Lbz
Aug 13, 2013
342
spokane wa
The blowthrough works great if ya know how a holley works and can tune it. That carb was set up by kevin at csu. He does a great job and the carbs are pretty close out of the box
Dirtymaxx03
3,109
Started as a .060 454 bored it another .010 and added a 4.25" stroker crank into the mix. Comes out around 498 CI
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Just a lil 383ci SBC, 76mm whistle ftw
[YOUTUBE]UvdwZnDQQ78[/YOUTUBE]
(prob posted that vid but F it, whore it out :D)
Big Block 88
Nov 3, 2008
4,665
This old gal had a M21 .030 over 454 bored and honed tbi high flow injectors port polished oval ports edelbroke victor jr. Intake with and adapter for the throttle body, .500 lift comp, beehives, it was a brute had over 300k on it would rev to 6k. Hauled over 50k gcwr with her could only do 45 and she was screamin butnit got it done till the ujoints gave up...
Dirtymaxx03
3,109
Any of y'all have experience with the gear vendors over drive units?
I'll be running a 3 speed Th400 behind this BBC and I like cruising 70mph without losing my hearing so looking for something to drop the RPMs when I'm cruising hwy speeds
