I know the 4l60e is garbage and when I asked around to find out if I could get it built everyone acted like it wasn't possible and that I should just upgrade to a 4l80e instead.
This Falco guy is on his 3rd or 4th turbo Silverado build, this one makes 1000+ and will hang if not beat out super cars like a ZR1 with a nitro shot
@50sec
http://m.youtube.com/watch?v=T7rjqr7V2hk
Check out 1320video...
That trucks pretty sick. I was just watching that video the other day. Makes me really miss my ls cars.
One day I'll build another one. Until now I need to focus on finishing my dmax build.
I know for a fact that the only difference between the 4.8 and 5.3 is the bore, a 4.8L can be taken all the way to 5.7, so can the 5.3L, creating an iron block vette motor, only it's capable of withstanding more boost than the aluminum block...:thumb: and then I think most if not all the LS1/LS2 stuff will work for the build.
Like I said, the bore is the defining element for the amount of displacement between the 4.8/5.3 they use the same crank and rods...it's been a few years since I was playing around with LS stuff, but I'm pretty sure you can bolt on LS1 vette heads once the blocks been bored over and even use a LS1 Z06 cam, with the right tuning that will surpass your 400hp goals with ease.
Lunati and comp make some pretty trick cams for the LS stuff, weisco pistons, JE pistons, Arais, MAHLE, any one of them would suffice, up you can even run a stroker kit wit a full 4" throw iirc???
I saw mention of using the 243 heads, but iirc, the bore on the 243 heads is 4.125 and while they can be used with a 4.05 bore or somethin, you have to pay special attention to the quench, piston wall to valve clearance and CR cuz the volume of the 243 heads is like 63cc iirc, and the standard heads used for those engines was a 72cc combustion chamber, also I think the valve angle is different too, 23* vs 15* but I can't remember
also the cathedral port heads can be ported out to match the flow of the stock square port heads, and even more so than the stock square port heads move, AND cathedral port heads flow better down low, producing more tq down low, which is beneficial for a vehicle as heavy as a truck, usually this detrimental to the top end, but if you can afford to send the heads out to somewhere like T.E.A (total engine airflow) you won't be disappointed something like the 225cc-245cc heads from them would be sweet
http://www.totalengineairflow.com/cnc-ported-cylinder-heads/gm/ls1ls2
Really, the sky is the limit! Build it for more than your current goals and go for it later with a turbo set up
Only way to tell the difference between 4.8/5.3 is to pull the heads. All the blocks are stamped 4.8/5.3.
WRONG!!!! So many things wrong with this post, 3.78" not your 4.whatever bore is the same 4.8 runs flat tops, very few 5.3 run them. ONLY DIFFERENCE is crank shafts so there for all too end parts are interchangable... 243 heads polished are skme if the best heads going for the ls and are amazing in boosted applications.
Read the post, I was referring to the bore size after being bored over to a 5.7L
And ported cathedral heads work well with boost too....
:thumb:
And btw, the cranks are identical, the bore is the only thing different...
You are wrong again. The 4.8 has a shorter stroke and a longer rod. The 5.3 has a longer stroke shorter rod. Same bore size between the two.
:thumb:
You beat me to it. I swear they had different rods.
You can interchange almost every part between the gen 3&4 motors besides the ls7. It had different head bolt and intake bolt patterns.
I believe it was also considered a big block.
I wasnt aware the ls7 didnt share head bolt layout, and intake patern. The guy i baught my polished 243 heads from and ls6 intake and valve train claims he was going to run an ls7 top end on an ls3. Id be interested to know if it is possible or not.
And i swear if someone pipes up and says the only block and ls7 can share heads with is an gen II lt engine im lobbying for a ban
I see, this guy was running a hone on the stock bore but aims he hould "fly" cut the tops of the cylinder bores for the valves to clear, unsure on this also as i would think there may even be piston to valve clearance issues. I think im gonna see him this weekend and i will try and figure this out.
