Had him check the manifolds already, cant see anything visible. He's also got 2 bottles/2 tanks of injector cleaner run through it. I used to work for BG, the 44k was the shit but theres no local dealers near where he lives. He's running the techron cleaner right now. I'll have him check the intake plenum again, not sure if a leak there would be audible or not. Already told him to drive it easy since its gonna be runnning hot with it leaned out.
Would a faulty MAF be able to cause this??
Thanks for the help.
most likely not MAF related or it would throw 174 and 175 for both banks....I wouldn't completely rule it out but usually both banks will be effected with a MAF issue. I'd lean more towards a bad O2, a faulty injector, or an exhaust leak. How many miles on the truck? If there are many miles on it (70kish) I would suspect an O2 first. One thing he can try is to swap those front O2's side to side and see if the code follows the O2 to the other side. Cheap and easy way to test that O2. If the O2 checks out and he's positive there are no exhaust leaks I would start listening to injectors on that side of the motor.
