I have a friend with an 08 LMM, he installed a 6" lift and droped the torsion bars to get it to 4" and his cv's line up perfect and it rides as good if not better than stock.
If you are really curious, remove your t bar adjustment bolts and drive around for a week or so, that ride will transfer over to your lift, cuz thats pretty much what you have to do to get a 6" kit to ride that low, and lowering by torsion bar has the exact oppisite affect on your ride as lifting by torsion bar, so instead of a suoer stiff ride, you get a super loose and sloppy ride. IMHO...i was thinking about getting a 6in then just lowering it just wasnt sure how they would ride. seems to be easier to get a 6in.
The cognito lift is kinda deceptive too, if you wanna do it up right it will cost significantly more than just the front box kit you see advertised, i wont use block for a rear lift either, so that add's some cost to the equation, but you will need a c/v drivline for the using the 4x over 20mph at a minimum, so add 550 to the advertised price, if you get some leafs add another 550 minimum for a mini pack set, upgrade to the fox shocks and add another 600, soo you see, the front box kit they advertise is deceptive, it is probably the most expensive lift out there once you add everything inIv seen the cognito and they are very nice but im not gona drop that coin on a lift even though itd be nice. ...
My truck, it has 140k but everything is newHow many miles are on your truck? What kind of shocks? The truck u say u pulled bolts for a bit to see what it was like.
Here is the loop, you could probably ride in my truck with the bars turned down and like it just as well, but i dont like it.... The results are no different from truck to truck and neither are my preferences, and i prefer to have the bars set up slightly tighter than stock, with fox shocks and poly bushings in the lca's^^^^^ thats my point. Ive had same results on tons of different set ups. Rides is twice what stock was.
The truck I mentioned that belongs to my friend has Rancho 9's on it. With the lift turned down from 6 to 4 and the ranchos set on 3 it rides like a dream.
No ball bustage was interpreted, the trucks do ride soft and almost "caddylike" with the t bars down, while i dont mind it i just dont prefer it, i like a little more feel, response and agility than lowered bars offer, in my opinion....lifted or loweredAnd to CoCo, I'm not trying to bust your balls, I have zero experience with lifted trucks. I love the way they look but Im just not into that. We all have different oppenions on what we like in a trucks handling and suspension feel I personally like to float like a Caddy when I cruising down the interstate.
Well, thats just it, the ride i like is only maybe 5% more stiff than stock yet probably close to 60% more responsive and considerably more rigid and capable of maintaining proper alignment while off roading, aggressively cornering and boosted launching.Yeah i know what your sayin coco, just wanted to hear your opinion all the way thru. Nothin personal. Your just the first person that ive met that actually wants it stiffer ride, not many out there like that.
