Just to clarify for readers, mark has a 68mm turbo that is an lly turbo that's machined to 68mm. It has a smaller exhaust housing. Basically an lly turbo with a larger wheel and I believe new vanes. That is why it cost more than the 4094 is because its machined larger.
He also has his 4094 which is a different turbo from Garrett that has a larger exhaust housing and turbine. It comes from the factory with a 68mm compressor and can be machined to 72mm which is the turbo that he is mostly known for.
Right, and you can also send him your stock vgt (LLY, LBZ,LMM) and have it machined out to fit a 68mm wheel as well, you can have a cast wheel dropped in or use a billet, they replace and rebuild everything so it is in a like new condition
:thumb:
