The coolant temp on the dash isn't as accurate as you would think. If you do a lot of towing look into a set of gauges like the CTS insite. Great tool to have for monitoring your engine vitals.
Get rid of that mesh, and all TT are crappy on milage, 4in without DP gets you nothing but sound, Put In DP and expect 200 Egt drop. If I tow a ball trailer I see 10, hook up my 5er at 13k i see 12-13 all day
Sent from my SCH-I545 using Tapatalk
The biggest restriction in the stock exhaust system is the muffler. Replacing that will get you the biggest EGT drop.
Out of the 3-4 mufflers I have tried the Corsa 4" SS Muffler :thumb: has been the quietest(no drone). EGT drops (around 150) are about the same since they are almost all free flow type mufflers.
