3 to 4 stutter on built tranny
Teamvi
Oct 26, 2011
333
I have an 05 lly with a built tranny with sumcoast stage 5 and 1058 converter
Was doing some tests last night on the street.
At wot the 3 to 4 shifts weird and stutters, only does it on wot that i could tell, any ideas??
Stock turbo and motor
Teamvi
Oct 26, 2011
333
Haent tried on the stock tune, just on 100 hp and 150, has moonshine efilive. Do you think i need a trams tune?
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
Shouldn't need a trans tune. He's probably trying to gauge whether the trans is taking a shart.
How long has that trans been in the truck?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
What are the specs on the build?
Have you logged rail pressure during the "stutter"?
I highly doubt it's tuning related if it's moonshine tuning.
N2BRK
2,054
371
Is the torque converter locking at the top of third and then shifting?
whytry
Oct 11, 2010
282
Is it like a "double shift"? If it is it most likely is a tie up..and is probably the way the c2 is setup.
whytry
Oct 11, 2010
282
Just re read the thread saw it was in for a year...in that case I bet there is wear on the c2 clutches
Teamvi
Oct 26, 2011
333
I ll have to ask the builder to see exactly what its got.
I know its a suncoast stage 5 kit with mike L springs and a 1058 converter,
Its like a double shift, almost like the tranny shifts the the torque converter locks. Anyone else had this issue at wot
malar24
60
NE Ohio
I ve got the same setup built trans/1058/ stock injectors and mines got a very similar feeling when it shifts from 3rd to 4th while the converter is locking right at the top of third. It ll also bark the tires once lockup occurs in certain situations.
N2BRK
2,054
371
That's why I asked. I fixed mine with Ben's box. It looks like you did too.
malar24
60
NE Ohio
Yeah I rarely notice it anymore since I ve been using Ben's box. I just assumed it's the nature of the beast in this converter and never really worried about it.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
When I was running a 1058 with a single 76 it would shift into 5th. Converter would lock and drop rpms causing it to down shift. Got trans tuning that bumped up shift points a little and never had anymore issues.
