3 to 4 stutter on built tranny
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
No changing turbos will not help.
You could log it and see if it is stacking converter lockup and the 3-4 shift on top of each other.
If it is stuttering on the 3-4 shift and the converter isn't causing it then it's a transmission issue.
Teamvi
Oct 26, 2011
333
I currently dont have a tranny tune. I ll log it when i get home, tony said i shouldnt need a trans tune, whos tranny tunes do you recommend? Would a lock up box work?
Robby05
Jul 25, 2014
498
Spokane, WA
Just re-read this thread. Is this your truck? Have any clue what was done during the build? Only ran on a 150 horse tune. Reason I ask is when my trans was done I couldn't wait to put it on a max tune.
Teamvi
Oct 26, 2011
333
I ve ran it on max tune but when i was testing it i only put it on the 150 tune and i normally run on the 100 hp tune for dd. I believe it has to do with the torque converter locking up
solidrunner
Seatac, WA
Pretty sure my truck does the same thing. Evan, is there a TCM tune version that you would recommend? I had a buddy that works at a dealership flash mine with the latest update when I had him learn the trans for me.
3,727
296
You would get a lot more than a tune file going to see Evan. You can get a TCM OS online and just flash it in with EFILive without leaving your driveway, if that is all you want.
Sent from my FlashScan V2
ieetgluu
Sep 27, 2013
29
I'm good to go, thank you
