2wd race setup?
674
heres the back end of mine.. BTW i got a CCLB as well.
i run with the tail gate on..
i have a 60gl tank in the bed when its full weight spilt its 3900/2900 with out me. i played arouns with the tank empty vs full.. i cut better 60' with the the tank full then empty
what is you tire pressure?
pick up a universal drive shaft form jegs ro summit.. for cheap..
May 21, 2008
1,141
Stephenville Tx
Wow, this took off over the weekend.
I run 30/14.0 M&H slicks I paid about $200 each and tubes were another $70 each, used rims for $150 a pair , 60' times 2.0,2.1. Cant break into the 1.x yet, 6000ft above sea level.
I do a small burnout to knock the rocks off the slicks and get some heat in the compound, I have a starting line video I will try to post.
I plan to move the fuel tank and Batt to the rear of the truck behind the rearend to help with transfer.
Has anyone built a drive shaft loop? I would like to build one for my own peace of mind, not required at Bandimere yet.
That is the same tire I have on stock pyo's with wheel screws and no tube's.My setup is rancho 9000's set at 3 in front and 9 in back,M&H's,2in shackle in the back with no overload,leveled in the front by the bars and cal-tracs with 1/4 preload.
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
with my slicks I went from 2.1 to consistent low 1.8 sixties.. Slicks help
1.72 is the best so far for me. I have ran as fast as 11.6x @118mph on Diesel #2 only with stock injectors/ 2 wheel drive slicks.
Well we don't do burnout's with them. So I can't help you there.
Thats no fun.....
all you need to do is heat them up and get a little smoke rolling off of them and thats all...
Where is the fun in that???
Well that is debatable also:D
We run ET Streets on the corvette. I can't do the 3 ft shuffle so I don't do a burnout. Pat does a big a$$ burnout because he thinks it's fun.. Who do you think cuts better 60ft times?
Me most times :hello:
now were talking!!!!!
quick haze of the tires to get allt he rocks and crap off them that i pick up getting to the water box
:rolleyes::screwy::driving:
I started at 15psi and dropped down to 12psi. Tire has not moved on the rim. Could go lower and screw the rim to the slick?
I have been down to 9.5lbs
possible... mark the tire/rim to see if they slip or not..
next major thing is less tire pressure means less stability at the top end of hte track..
Correct! it gets to be a handfull at times. Especially when there is oil at 3/4 track.
12psi on a slick? Wow I run 25
Have you tried less?
Here is a video of some fun at the track... Slow run though.. I usually run 7.5-7.6 @95+mph
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/YCyeR0XiTls&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/YCyeR0XiTls&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
More...
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/PkwauxLGlWc&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/PkwauxLGlWc&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/QxLOHlYNewI&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QxLOHlYNewI&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/or-CJ1g-XSs&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/or-CJ1g-XSs&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
