2wd race setup?
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
I got mine from a guy on here for 650 for raceline wheels an slicks... U can get them out of jegs for like 420$ for just tires and YOU can mount them on stock wheels.. My friend tylerrustlb7 put his 14.50 wide on stock take off rims an they work badass...anymore questions I will be glad to answer
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
thanks...yea i was planning on using the stocker rims anyway......
uh just 2 more quick questions if ya dont mind...1 approximately how many passes can one realistically get out of a set of decent slicks? and 2 how can you tell when they are worn down and need replacing if they are all smooth? thanks..
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Don't know the exact amount but a lot... They have wear pockets.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
gotcha...thanks kat i just dont wanna get a set then need new ones in a few weeks...i like to do mean burnouts before i stage up lol..
so would a wear pocket be like a little hole you can measure the depth of? i apologize for my ignorance on the subject.
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
Well we don't do burnout's with them. So I can't help you there.
Exactly...
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
all you need to do is heat them up and get a little smoke rolling off of them and thats all...
Well that is debatable also:D
We run ET Streets on the corvette. I can't do the 3 ft shuffle so I don't do a burnout. Pat does a big a$$ burnout because he thinks it's fun.. Who do you think cuts better 60ft times?
Me most times :hello:
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
I never burned out for more than ten seconds... Tyler did a big a$$ burnout an saw no changes.. His 60 was a littler slower due to suspension issues..
2,043
You guys need to get ahold of Brandon Meyers (BMDMAX) from the DP. He knows his stuff about racing a 2wd Dmax. Hes run 12.20s on fuel only, 11.90s on N20.
674
hmmmmmmmmmmmm didnt know that!!
2,043
are you saying we dont know what we're doing?
No, but he would be another good source for info on what he did to hook his truck at the track. Going back and reading, he was netting 1.7-1.8 60ft times in 2006 on slicks, caltracs and stock shocks, so he must be doing something right. Any info is helpful, right?
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
with my street tires you can forget about hooking if you dont do a burnout...however i have found long ones dont help at all either...well besides putting a smile on my face lol
i usually powerbrake just till they start spinning then get off the brake and let em roast to the line...make a total of 5 seconds? that seemed to work best for me...but then again slicks is probably a whole different story
seven3smoke
Track Rat
Aug 28, 2009
33
Denver, CO
Wow, this took off over the weekend.
I run 30/14.0 M&H slicks I paid about $200 each and tubes were another $70 each, used rims for $150 a pair , 60' times 2.0,2.1. Cant break into the 1.x yet, 6000ft above sea level.
I do a small burnout to knock the rocks off the slicks and get some heat in the compound, I have a starting line video I will try to post.
I plan to move the fuel tank and Batt to the rear of the truck behind the rearend to help with transfer.
Has anyone built a drive shaft loop? I would like to build one for my own peace of mind, not required at Bandimere yet.
