The wow factor is definetly through the roof, cant argue with that...but why??? Is it necessary? How is everything going to fit? Are you going to be able to keep AC and all the radiator shrouds? Be able to keep the batteries and underhood fuse box? Where are the dual CP3's and accessories going to be mounted?
How do you possibly expect the trans to live? Theres also going to most certainly going to be issues with the block moving around at that power level...I just cant possibly see it as "daily driver" IMHO.....
ben
Not only that, but what is done to the motor as far as rods, cam, or pistons, head work or a stroker kit?
Im going to have to assume the motor is fully built.
Also, Will concrete be used on this build?
are those 2.8's or 3.0's
The wow factor is definetly through the roof, cant argue with that...but why??? Its never been attempted and thats what we shoot for at our shop Is it necessary? NO but why not try, if this pans out the whole gas drag race community is in a rude awaking. How is everything going to fit? Very uniqe and very carefully with lots of time and new designs from everything to how to hook up a second CP3. Are you going to be able to keep AC YESand all the radiator shrouds? going to try and keep it Be able to keep the batteries Its going to get relocated and underhood fuse box? Where are the dual CP3's and accessories going to be mounted? As close to factory location as we can possibly get
How do you possibly expect the trans to live? We suggested the duraflite but customer wants to stick with ATS b/c they are going to warranty it if it fails.....Theres also going to most certainly going to be issues with the block moving around at that power level...I just cant possibly see it as "daily driver" IMHO..... I agree but Tunning is going to be a major part in its ability to be a daily driver
ben
Not yet but soonIm going to have to assume the motor is fully built.
Yes SoCal diesel is going to be part of this build the whole way,can you say.... Ungodly, destructive amounts of torque! That sucker is gonna be insane at the slightest tap of the throttle even at idle! I do hope its got all the parts in the book thrown at it! cause ita need em!
Very:cool2:
Oh its going to be a fun truck, Lots of relocated parts for sure. Wiring will have to be made to fit around the blower. Its not that hard, just tons of hours worth of work. Im really not sure how the driveline is remotely going to handle it. But as for the motor, its getting a lot of one off custom parts and concrete. Im more worried about the pats behind the motor!
With the new open driveline rules Fantasy will have, you should just put in a drop box and call it a day
