LBZ: 2006 Eng Vibration between 1200 to 1500 RPM
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Yeah im sure it would, but if you break a 1\2" breaker bar doing a dmax water pump job then that tells you it wasn't very high quality.
I don't own any 3/4" tools and I have never needed them on a dmax.
:roflmao:
The water pump bolts can be removed with 1/4" drive tools, the pump itself is cake
It's the crank balancer bolt that's the beotch!
Lucky you that you haven't needed any 3/4" drive tools for any work you've done on a D-max, I hadn't needed any either...until I did!
I've read now of several guys that have broke a 1/2" drive bar at the head trying to get that damn bolt free, if it could possibly save a guy some headache and maybe some broken tools and money (either in tools and/or collateral damage) in the long run I figure why chance it...from my experience a 3/4" drive breaker is a better option
:hug:
I try to give the best advise I can and know up-front whenever I can, I broke a 1/2" drive breaker bar on the balancer bolt, it wasnt Snap-On or Matco quality, but it was decent and it was practically new.
02greysixer
1,829
North Central FL
I bent the hell out of my 1/2" breaker bar on the last water pump I did. A 3/4 drive is better, even if it is a cheap harbor freight one. It's kind of like towing 10k lbs with a 1/2 ton instead of an HD. It can be done but there is an easier safer way.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
:roflmao:
Thank you Capitan obvious... What's involved In a waterpump JOB... Removing the crank balancer... :thumb:
All im saying is yes 3/4 drive is probably a good idea but my 1/2 did the job just fine with no signs of breaking and I'm still using it today, and I use my MAC tools professionally so its not like it was brand new when I did the job.
2,010
Guys, are you really arguing about breaker bar quality in this guy's thread? Seriously? :doh:
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Are you running twins / triples or any other accessories hanging off the side of the motor? I had a cracked brace on a set of twins that had this symptom.
Macon Rounds
Sep 11, 2014
Engine Vibration Eliminated
Up date on engine vibration problem. SHortly after making this post my engine squaked a Mass Air Flow code. So i changed the MAP sensor and installed a new air filter. Vibration was still evident at the 1200 thru 1500 RPM range but was greatly reduced and almost not noticable. Further research and advice from a certified GM mechanic suggested useing the Diesel fuel additive "STANADYNE" ...... It worked !!!!! after running two tanks of fuel with STANADYNE mixed as recomended.... The vibration is GONE !!!!
Hope this helps some of you other fellas.
13,746
821
That's good to hear you got it figured out, and thanks for updating us on the fix. :thumb:
