2 wd crew cab 11.17 on tune 3
2,043
60' sucked the track temp was around 68* to 61* all night and the really good pass he didnt bring up the turbo enough. They were all around 1.82 to 1.88 really bad:(
What is your current setup for the suspension? What are you going to try to solve the issues you're having? Just curious.
BTW, long time ago, Branden Meyers out of Sharpsburg, GA used to run a 2wd CC. He had some very good ideas on suspension setup for his truck back then. He hasnt been on the forums in a long time, but you could email him for ideas. www.bmdmax.com
05chevy
1,086
U ever think of going with a ladder bar and a slider with the leafs or just go with a labber bar or 4 link with coilovers and just get rid of the leafs. Should leave like a prostock drag car if setup right
1. We took out all but 2 leafs.
2. located both dual adjustable shocks behind the axle.
3. Rotated the spring perch back to give it a 4* downward pinion angle.
4. Added caltracks (they are parralel to the ground now)
5. Got some realracing (16-10)rims with 30-14-16 M&H cheaters
This weekend
1. little less tire pressure
2. Moving the caltracs to the top hole
3. Adding 90-10 qa1's to the front
4. adding 200lbs balast to the rear just to try
5. Doing some adjusting on the rear shocks
Not all at once just going to try out some options before we move to the ladderbar back half.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Don't think this truck is on the dmax quick 50 list, would you give me some specifics please. Year (01 or 02 chev right?) Owner is DTS, et is 11.17 what is the best mph you have ran in the 1/4 mile. the et and mph do not have to be on the same pass. Also who tunes the truck and does it run an allison or some other transmission? Thanks and congratulations:thumb:
01 chevy
owner: Matt mobley(painter)
et:11.13
mph: 129.53
tuner: (A....T.....P!!) Robert Coddens daggum Idaho potato
trans: DTS Allison
