Here's the beginning of my stainless gauge panel. When I was done with it, I wasn't happy with it. It was too big and bulky. When sitting in the car my knee would block 1 1/2 gauges, so I eventually cut it in half.
I'm still chuckling about the stock AM radio. I remember those days. :roflmao:
Car looks great! I agree with the other guys that the no-start is in the tuning.
anyways, first...... you do not need the TCM at all. as long as the wiring is correct it will fire without communication with the TCM. I was told that several times when switching over to the LBZ and not true
I'd recommend you give Russ at RPM Performance &/or Rob at ATP or Jeff Dean (stingpuller) or Ben @BT Dieselworks a call in addition to PPE. All have experience with lbz conversion vehicles & have a good understanding of the required tuning & potential hiccups.
I feel your pain and wish I would have read this thread this morning before we left Fortuna. we took 101 all the way to santa rosa for the drive home, we could have probably stopped by and checked it out, maybe given you a hand in getting it running. I think your in that neck of the woods, right?
anyways, first...... you do not need the TCM at all. as long as the wiring is correct it will fire without communication with the TCM. I was told that several times when switching over to the LBZ and not true.
second, the VATS will be an issue but it should still allow it to fire and then die. ive ran into that issue with my LBZ, as the tuning I run is locked and a couple times it came not disabled and that's what it would do. fire, run for a few seconds..... maybe 2, then die. but it did run, not just crank.
third, it sounds like a fuel issue.......... only because of the fact that it will fire with the starting fluid then die. so, do you still have the stock filter head?? how about the fuel lines...... return lines.......lift pump..... all of that needs to be looked at. you said you have EFI live, use it if you do it will help figure stuff out. even while cranking.
give me a call and we can trouble shoot over the phone.
Rick 209-986-9706
