Looks like I'm a little late to give advice here, but it looks like everything is pretty much covered already. For tire pressure, I would recommend about 30 front and 25 rear. I don't clamp my springs, but it shouldn't hurt if you do. I'm just too lazy is all. I've been meaning to do a comparison between clamped and unclamped to see how my 60' times change. I guess it'll have to wait until the truck is back together. I lower my torsion bars until the CV axles are pointing up slightly (my truck seems to sit lower than most so I still have quite a bit of adjustment in my bolts, but some people have to lower theirs all the way to get their truck to sit like mine). I leave at about 2100 RPM with about 15 psi of boost. I run stock PYO wheels with a set of worn 265 A/Ts and cut mid-high 1.6 60' times.
I think maybe you smoked the lights. There's no way you cut a 1.4x 60' with your mods.
I ran 35psi in my front tires and 30 in my rears. Left somewhere around 13-15lb's of boost. As far as smoking the lights, do you mean redlighting? If so I was not aware I did. Would it tell you on your slip?
