13.30s with super low rail press!
paint94979
Beer Nazi
Sep 18, 2006
11,715
Yeah oh a big tune it only holds around 20K and its getting around 2900 pulse
Hmmm i just looked at an old log of my truck with a 3300pw tune and LBZ Regulator my truck held 22,000psi+ and it would spike up to 25,000psi.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
you might need to adjust b1015 desired flow vs current.
thats the lbz table # not sure if its the same for lb7
03-GMC
Let there be light!!
Mar 26, 2009
485
SLC, Utah
Man just think what I could do with 3300 pulse. Yeah something is wrong now I need to track it down. :confused:
03-GMC
Mar 26, 2009
485
SLC, Utah
So when I commanded to the 180MPA the number 8 injector balance rate went way negative. Should that be anything to worry about?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
The table needs to be different at idle ranges but it will no effect rail pressure at WOT .
Just a FYI my truck with a LBZ reg would hold 21.5-22.5 k with a 3250 pulse when i had stock sticks and stock pump .
03-GMC
Mar 26, 2009
485
SLC, Utah
And mine dips down to 19 k on 2900 pw :eek:
