12.1 @ 116 :d
paint94979
Beer Nazi
Sep 18, 2006
11,715
Not sure what i can do... with the GT4094 my numbers match almost exact to the S475, i think my best ever on the 4094 was a 4.97 330' 7.71 1/8th 12.10 1/4. I drop a tenth on my 60' on my second pass and only picked up .03 on the 330'? Not sure if my CP3 is the issue? as the truck pulls on the top end but no matter what i try 1/8th ET stays near identical, me and everyone else that has helped me agreed i should have seen some change slower or faster none the less a change. Engine runs great, no leaks, nothing that jumps out. Im sure i can work on my 60' as i am still trying to leave at the right boost... It's getting down right ridiculous BTW trans shifts good
#1
60' - 1.798
330' - 5.050
660' - 7.777 @ 91.409
1000' - 10.151
1320' - 12.145 @ 116.080
#2
60' - 1.696
330' - 4.978
660' - 7.727 @ 90.969
1000' - 10.113
1320' - 12.113 @115.774
Righteyeblind
712
Fairbanks, AK
That charger isnt going to have the bottom end your 40 had so 1/8th mile is probably going to be slower but fly in the top. Thats what I saw with my 472 and now my twins mph is lower but et is down and 1/8th mile is way down.
NOt as much torque as your 40 either im sure.
Congrats on the times though. Holy MPH for sure though!
paint94979
Beer Nazi
Sep 18, 2006
11,715
I ran 7.7's with the 4094 and 7.7's with an S475 that isn't right you're saying that the S475 shouldn't give me anymore power on the bottom end over the 4094?... now i have to throw Dual CP3's at it:mad:
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
It wont get any faster with Dual CP3's. I would try more timing, RPM, and pulse. or injectors.
You ever get your converter to lock?
paint94979
Beer Nazi
Sep 18, 2006
11,715
pressure between shifts drops and recovery time is shit... it holds 26k in 5th but lacks power in all other gears, that is why the CP3 is suspect
Righteyeblind
712
Fairbanks, AK
Yeah my 4094 was way better on torque then my 472. My 472 tq curve was short. 4094 was a lot longer. I can't imagine what it looks like with my twins. Log converter lock up. That was an issue with mine.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Nick Tried to call you this week and missed your return call. We are headed to Sac. wed. to get a customers LMM hopefully into the 12's. Can you make it? Last outting he went 13.4 on a tune, trans, stock TCM tune, 8" of lift, straight front axle, cutting 1.9 60's ;). With some fine tuning/setup and a TCM tune, it can be done... He might want your Itty Bitty's and PYO's as well!
5,818
boy nick, all that jokin about not beatin your 12.1 or hittin the same time with the new charger came true! that jsut no fun!
You got a log of what its doin throughout the gears no tholding rail pressure like your sayin?
