LB7: 1058 and what turbo???
minerigger
2,660
Casper, WY
That fleece 468 is supposed to be one bad sob...when in upgrade to the 400 frame its either 468 or 472
Sent from my DROID RAZR using Tapatalk
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I still am a firm believer a s366 is plenty for stock rods. 6-700hp range. They spool great and cost only 500 new. I did try a billet wheel. Seemed like it gave me more midrange and that's it.
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
I'd rather have a 464 or 466 if you wanted a s300..the shafts and internals are stronger and just a cheaper charger..you can detune to run a 472 and have a good base charger if you decide to build engine..there are other guys out there that take shelf BW chargers and put the same stuff in them as bigger companies or 1/2 the cost..
minerigger
2,660
Casper, WY
Yea for sure. I think a 468 would be awesome but agreed on price is like wowzer! But if I did one is research the hell out of it so as to get one cheaper
Dirtymaxx03
3,109
I remember when if someone would ask about a turbo, they got nailed with 20 posts about an s366 lol. Now it's an s472
For what it's worth, I went straight to the s472, stock injectors and cp3. It's badass. It would be even more badass if I had the proper torque converter.
Driving around town is no problem at all. How fast it spools all depends on the rpms you give it pre boost. If I had a lockup switch and the right TC I bet I could light this turbo instantly.
Dirtymaxx03
3,109
I don't even know what stall it is. Pretty sure it's a PPE TC. Cheap local build, invoice said billet triple disc. Pic and price matched up with the PPE unit.
minerigger
2,660
Casper, WY
What color? I think mike l said the yellow was a suncoast 1056 and the pink is a precision ml but don't quote me. I found it one day researching converters
minerigger
2,660
Casper, WY
Maybe that's it...hell I dunno. In just remember seeing mike l post about what colors were what
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
If your doing a full build then the cost of going from a 66 to a 72 is nothing. So why not have a better reacting turbo tell then?
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
472 over anything else. Get the 87mm turbine and a 1.0 housing. Spend the extra money on the newer technology. The differnce between a regular billet 472 and a TCT 472 is night/day. I would say from personal experience that the TCT wheel is about 10x quicker to spool and drives exactly like the stock charger.
And to answer another question, I have my TCM tuned and it also makes a huge difference in how the truck drives. A good tcm tune can turn a laggy charger into something much more responsive just by raising shift points and wen the tcc locks.
minerigger
2,660
Casper, WY
Thanks for the info Chris. I enjoy hearing your input from personal experiences with all the mods you have done and different setups you've ran
DMAXchris
Apr 28, 2009
2,273
Natrona Heights PA
I haven't ran that many, but I've been in quite a few modded dmaxs. I got to drive my cousins truck with a TCT 472, prob a hundred miles the other day. It has 100s/2xcp3 and it honestly shocked me. His charger makes 10 psi when mine would be barely moving the needle. No need to go above 30% throttle and it accelerates to 60 just like a stock truck, prob a little quicker. We also pulled around 7k a couple weeks ago through the mountains, it never missed a beat and egts didn't go above 1100 while ragging it up the hills.
minerigger
2,660
Casper, WY
That is some extremely good real world info. Guess I'll be hunting a tc 472 next go around and so fuelage to feed it
BowtieClub
Mar 3, 2014
29
The QC, N.C.
Thanks for all the replies guys! I've been a little busy with this...
mtl_dmax
Dec 7, 2010
114
Eastern Canada
