1/4 mile discussion and time slips post here!
5,931
1/4 mile 10.999 second or quicker Duramax powered list
Kinda. the 9 second crew cab cummins here in AZ has gone 1.40 on my old 30x14x16's and it's 6330lbs.
I went 1.62 on the same tires at 5300lbs.
Yeah but you never got your suspension as dialed as him. You had a lot left
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Nice pass, I just got back from the UCC and have a ton of things to do, I'll update tomorrow just in case there are more entries, is everything else the same? Congrats on getting into the 9's. :thumb:
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
5750 weight and it has a duraflight. Rob had a good showing at UCC. Did you enjoy it?
Subman
Old Geezer
Jun 27, 2008
3,233
80
Yes it was a lot of fun, too bad the drag racing didn't have much weight in the overall point systems, but yes Rob did great and would have done even better if the drive shaft hadn't did the pretzel trick it did at 244 feet in his second pull, but all in all he did great since all he brought in the way of spare parts was an extra serpentine belt. Did have to overnight a new Flexplate after the first one sheared the bolts on the first pull on the dyno.
Subman
Old Geezer
Jun 27, 2008
3,233
80
1.NGM Diesel Dragster 7.02 @ 195.48 (9-4-15) 2050 lbs, Turbo 400, Johnboy
2.Banks Dragster 7.170 @ 181.08 (4-30-09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
3.NGM Diesel Prostock 7.44 @ 187.55 (6-1-13) - 2800 lbs, Turbo 400 - Johnboy
4.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
5.Banks Sidewinder Type-D Prostock 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
6.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
7.Batmobile prostock 7.843 (9 -12-15) @ 177.23 (4-11-15) - 2700 lbs, LBZ,Bruno/Lenco - Milliken
8.John Sleath, (UK) S-10 Prostock 8.3664 @ 167.30 (10-31-15) - 3350 lbs, LB7, 4L80E - Sleath
9.Comp461 dragster 8.508 @ 161.05 (10-4-14) - 1965 lbs, Powerglide/Gearvendors - C. Byden
10.bcdeutch731 C-10 8.556 @ 161.67 (11-1-15) - 4610 lbs, LLY, T-400, 2x4 - DP
11.Dirtymax prostock 8.63 (6-16-12) @ 158.23 (5-19-12) - 3268 lbs, LB7, Lenco - ATP
12.RPM Motorsports 73 Nova 9.150 (10-26-14) @ 155.49(6-6-15) - 3460 lbs, LBZ XP 5 Glide, ATP
13.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
14.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
15.Trippplemax #1, Ill Tempered 9.24 (9-12-15) @150.20 (5-30-15) - 6005 lbs, LBZ Stroker, Durflite - C. Buhidar
16.Max'd Out 9.360 (10-15-11) @ 154.40 (5-7-16) - 6050 lbs, LBZ, Duraflite - ATP
17.K Douglas C-10 9.393 @ 147.46 (10-4-14) - 3100 lbs, LBZ - 2x4 - G&J
18.Trippplemax #2, Road Rage 9.459 @ 146.45 (8-8-15) - 5950 lbs, LBZ, stroker, Duraflite, C. Buhidar
19.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - 5950 lbs, LB7 - Dmitri
20.Merchant's Sandrail 9.62 @ 138.90 (6-27-15) - 2000 lbs, LBZ - Dmax Tuner
21.Industrial Injection shop truck 9.638 @ 154.99 (8-22-15)- 6040 lbs LB7 - Duraflite, Starlite
22.SmoknDmax05 9.655 @ 140.23 (5-7-16) - 5750 lbs, LLY - Duraflite, Fleece
23.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
24.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
25.J Hyatt 9.748 @ 150.78 (2-20-16) - 6300 lbs, LB7 - ATP
26.cafryer 9.769 @ 145.02 (8-16-14) - 6500 lbs, LB7 - Duraflite- Starlite
27.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
28.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
29.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
30.Orange Crush 9.875 @ 139.41 -(9-25-07) - LB7, 2x4 - TTS
31.Mika (FIN) 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
32.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
33.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
34.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
35.Dmax Tuner 9.995 @ 138.89 (10-8-15) - 5500 lbs, LB7 - Dmax Tuner
36.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
37.IBDMAX'IN "Skeeter" 10.046 @ 144.13 (4-23-16) 6280 lbs LB7- 2x4 - Wade Boyd
38.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
39.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
40.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
41.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
42.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
43.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
44.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
45.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
46.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
47.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
48.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
49.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
50.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
51.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
52.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
53.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
54.Hondarider 552 10.578 @ 133.88 (4-6-14) - 5400 lbs, LB7- PPEI
55.Meshanic 1/2 ton 10.5816 @ 133.97 (11-14-15) - 5400 lbs, LLY - Meshanic
56.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
57.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
58.White Devil 10.672 @ 132.62 (4-24-15) - ?, LLY - CaptPhil
59.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
60. IBDMAX'IN "Blue Angel" 10.71X @ 131.XX (2009) LB7 -Wade Boyd
61.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
62.Mike Diesel 10.725 @ 134.97 (4-23-16) - 7000 lbs, LLY - Starlite
63.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
64.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
65.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
66.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
67.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
68.Maine04max 10.825 @ 128.73 (10-3-15) - 6920 lbs, LB7 - Main04max
69.NLDP 10.85 @ 123.35 (6-24-06) - 6300 lbs, LB7 - TTS
70.The Dumpster Van 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - JoshH
71.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
72.Scott Mathews 10.9022 @ 127.44 (11-7-15) - 6800 lbs, LLY- Diesel Addiction
73.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
74.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
75.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
76.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
77.Joegorby 10.984 @ 125.94 (8-14-15) 6750 lbs, LMM - PPEI
Subman
Old Geezer
Jun 27, 2008
3,233
80
16.Max'd Out 9.360 (10-15-11) @ 154.40 (5-5-16) - 6050 lbs, LBZ, Duraflite - ATP
18.J Hyatt 9.458 (5/5/16) @ 150.78 (4-23-16) - 6300 lbs, LB7 - T Martino
19.Trippplemax #2, Road Rage 9.459 @ 146.45 (8-8-15) - 5950 lbs, LBZ, stroker, Duraflite, C. Buhidar
20.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - 5950 lbs, LB7 - Dmitri
21.Merchant's Sandrail 9.62 @ 138.90 (6-27-15) - 2000 lbs, LBZ - Dmax Tuner
22.Industrial Injection shop truck 9.638 @ 154.99 (8-22-15)- 6040 lbs LB7 - Duraflite, Starlite
23.SmoknDmax05 9.655 @ 140.23 (5-7-16) - 5750 lbs, LLY - Duraflite, Fleece
24.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
25.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
__________________
Subman
Old Geezer
Jun 27, 2008
3,233
80
59.2themax2 10.687 @ 129.06 (5-21-16) - 6700lbs, LMM - Starlite
60.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
61. IBDMAX'IN "Blue Angel" 10.71X @ 131.XX (2009) LB7 -Wade Boyd
62.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
63.Mike Diesel 10.725 @ 134.97 (4-23-16) - 7000 lbs, LLY - Starlite
64.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
65.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
66.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
67.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
68.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
69.Maine04max 10.825 @ 128.73 (10-3-15) - 6920 lbs, LB7 - Main04max
70.NLDP 10.85 @ 123.35 (6-24-06) - 6300 lbs, LB7 - TTS
71.The Dumpster Van 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - JoshH
72.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
73.Scott Mathews 10.9022 @ 127.44 (11-7-15) - 6800 lbs, LLY- Diesel Addiction
74.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
75.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
76.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
77.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
78.Joegorby 10.984 @ 125.94 (8-14-15) 6750 lbs, LMM - PPEI
Awenta
4,090
CT
Nice pass! She's got a good bit left in her. Nice 60 for blowing them off the line.
Can't wait to see the passes when you get more seat time in it!
Subman
Old Geezer
Jun 27, 2008
3,233
80
1.NGM Diesel Dragster 7.02 @ 195.48 (9-4-15) - 2050 lbs, Turbo 400, Johnboy
12.RPM Motorsports 73 Nova 8.902 (5-28-16) @ 155.49 (6-6-15) - 3460 lbs, LBZ XP 5 Glide, ATP
__________________
Subman
Old Geezer
Jun 27, 2008
3,233
80
4.Batmobile prostock 7.469 @ 185.41 (6-4-16) - 2700 lbs, LBZ, Bruno/Lenco - Vollmer
5.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
6.Banks Sidewinder Type-D Prostock 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
7.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
33.IBDMAX'IN "Skeeter" 9.924 @ 145.23 (6-416) 6280 lbs LB7- 2x4 - Wade Boyd
34.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
35.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
36.Dmax Tuner 9.995 @ 138.89 (10-8-15) - 5500 lbs, LB7 - Dmax Tuner
37.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
__________________
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
I wanted to post this up for Alex Tucan in his 04.5 Lly Ecsb truck got a new personal best and the Vgt full size truck record today! Truck is running my 72stg2R/TCT483 twins with some spray! Runs Evan@LimitlessDiesel Allison Trans and my tuning! We will get the weight of the truck soon but it should be 6400-6600lbs if I had to guess. Congrats to the Tucan crew!
Kyle Harbin will be posting up his new personal best shortly also! Ran into some extra issues that held it back but truck was still impressive as hell!!!
Harbin_22
3,858
Southern Indiana
I'll get the slips uploaded, but mine went 10.41x @133ish. I was hitting a limiter at 129mph area and just coasting for the last 1/4 of the track. Sucked but still happy with the times for some crappy 1.7ish 60'. Alex truck was crazy for what it is.
S Phinney
4,008
Quncy, Fl
Is that fuel only too?
