Hey guys I'm new to the sight and hope I'm posting in the right spot! I've got a 08 lmm in the shop the engine was fully rebuilt and when I set the cab back on it and got everything hooked up it won't start of course. A p0341 code comes up. So I pulled the cam sensor and noticed a rub mark on it. Swapped it for another and it also rubbed. I also pulled the pins out of the harness and ran 3 test wires eliminating a possible pinched wire. After eliminating that and having the proper 5 volt reference I resorted to taking the front of the engine apart to investigate the rubbing. I was hoping to see the reluctor wheel somehow put on wrong but looks right. Only thing I notice is the camshaft gear has a lot more gap between the block than the blown engine I have sitting here, and that's why the camshaft sensor is rubbing the reluctor wheel. Anyone know if the bolt can be re-used and what gap is normal? If that's not the problem could the ecm be bad? THANKS IN ADVANCE
Sent from my SM-G935V using Tapatalk
