LB7: ‘03 No Start Without A Little Help
9,905
151
I had like 12 selected. Same thing. Never EVER have I had issues like this before.
9,905
151
Doesn’t matter though. Checked right bank return rates. It’s around 25ml so looks like I’m doing the injectors. I was actually pretty sure they were bad just by how it idled but without the haze and overall return spec I was skeptical. I like to eliminate the other stuff before I throw money and time at things like this. Previous owner threw a cp3 at it hoping that would fix it.
9,905
151
Thanks for the help folks. Got it halfway in my tent and starting to rip and tear. Hope to have it all apart by tomorrow night. My only concern is
A: being able to get the injectors out as I don’t have the tool and all my heel bars are at work and
B: the age old dilemma to pull cups or just reuse and reseal the ones that come out on the injectors
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Pull. Pull pull pull pull pull I don’t know how much I can stress this there is literally no reason to do injectors twice. My injectors came out easy. Just A bit of prying. Like with a small pry bar or flat screwdriver.
2,207
Both times I did injectors in my LB7 they came out easy without needing a pry bar
I also didn't pull and reseal any of the cups. Didn't have any leaks. With that being said, most here will likely agree that pullimg the cups is the best idea
9,905
151
The way I see it, if the injectors come out easy, it’s highly unlikely you disturbed the seal on the cups. All 4 on the easy side came out easy, still got Vaseline on them from the injector change number 2 done 200000km ago.
One thing I noticed is #5 came out with absolutely no soot or carbon on it. The other three all were carboned to some extent.
2,207
Looks like you are making good headway. My injectors has little to no carbon on them too.
Just a little twisting and pulling and popped out. Put one of the injector lines on as a handle to pull on while twisting
9,905
151
All out. No cups came with and all the injectors came out fairly easy. The back 2 on the D/S needed the injector line handle trick but weren’t too bad. Need to find one injector harness that I found zip tied together at the connector, injectors and some seals and do it all in reverse.
9,905
151
Check / adjust the valve lash while you are in there
Ya was going to spot check a couple at least. Almost 160 000 miles on it. By the looks of the oil inside the hot pipe it looks like it might be needing a turbo soon also.
9,905
151
Hmmm. I’m literally using 7.5 scan tool right now on an lmm
Some time in the next couple days I’m going to hook it up to my lml and get it sorted out. Even if I have to completely reinstall both v8 and 7.5. Tired of fighting with it.
9,905
151
Core injectors sent out. I’m going to try a shop in Quebec that does a lot of common rail stuff so I can get a quick turnaround without having to deal with duty and customs charges. Will see how they turn out.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Unless they are a Bosch certified remanufacture then don’t waste your time and money.
9,905
151
Not sure what their credentials are. I just know a buddy has used them in the past for stuff and they were good for him. They do mostly Bosch only and also are a training facility. For the price time frame and considering this truck isn’t hanging around once it goes back together I figured it was worth a shot. Can’t be any worse than pensacola.
9,905
151
Anybody know if there is any difference between an lb7 and lbz cp3 other than the regulator?
9,905
151
Injector shop got back to me. Tore my injectors down and said the nozzles and control valves were all junk. They were surprised the truck even ran lol.
5,911
Told ya :hug: :D
You just going with rebuilds or the new SAC nozzled ones?
9,905
151
Ha. I was lying to myself in hopes I could avoid doing them. It’s still weird it ran as good as it did with no idle haze though.
Just remans going in. Not keeping this truck for long.
