Purchased my dream truck 03 duramax extended cab shortbed. Was told truck had injector problems by owner. Wanting a project i could learn from i purchased it. Checked balanced rates on all cyls. Showed a few a bit off. Will post pics. Truck smokes a bit at idle. Then gets really bad at acceleration. Was told to check rates, compression and other things. My scanner showed cyl 6 having +-5.6 other no more than 3.01. Compression was average 340 on drivers all 8. Did the hard upper rad hose in am test and had no pressure. Also truck doesnt spit coolant nor does it consume coolant. Trucks oil did smell a tiny bit like diesel but not major. Removed driver side injectors found cyl 6 body seal pinched from previous install. Also found most of needle seats worn to a point where your finger nail gets stuck at seat area. Tested injector solenoids and tested all within 0.05 ohms. Could the worn seat in needle cause excess fuel. For knowledge purpouses could just replacing nozzles fix problem. I have ultrasonically cleaned injectors and do not have debri in them. Also i know that its easier to replace injectors but want to know if anyones done the nozzles only and fixed issue
