03 duramax lb7 smoming at idle. Looking for answers
Dirtydmax86
Dirtydmax86
Jan 2, 2017
17
Sacramento ca
Nozzles are but one area. Bodies don't wear out, the ball seat and solenoid ball is what wears out on high milage units. Only a bosch dealer with the required calibration equipment can purchase the required parts to rebuild them completely. Many have bought the diy nozzle kits, and almost all of them end up smoking afterwards.
As to smoke colir, injectors CAN smoke blue. I have actually yet to have an lb7 come to me white smoking needing injectors. I've had one grey smoking, but the majority have been blue smoke. Just did mine for blue smoke. Doing the GM cleaner cleared up most of the blue smoke, but it would randomnly blow out a plume of blue after flushing. Remember, diesel is fuel OIL, and burns by compression same as oil will. Dribbling nozzles can easily cause blue smoke from fuel entering before cylinder heat is high enough, but not enough fuel entering to put the fire out(thats what causes white smoke).
So in that case if its white smoke doesnt mean injector is problem.
Sent from my SM-G928T using Tapatalk
03blkdmax
Turbos are cool
Jan 23, 2016
22
PA
Run ur truck with the valve covers and return lines removed..obviously u have to put high pressure lines back on.. see which if any injector returns a lot of fuel, the return should just kinda bubble a little fuel, not a teaspoon per pulse lol.. if any leak alot, replace with bosch reman and put new nozzles on the rest and u should be good to go, Worked on my lb7
Dirtydmax86
Dirtydmax86
Jan 2, 2017
17
Sacramento ca
Im assuming hp lines obviously on and return hose off right.
03blkdmax
Turbos are cool
Jan 23, 2016
22
PA
Yeah,and if the truck started hard u might have high return rates, but if it popped right off then its probably just nozzles.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
White smoke can be coolant, or it can also mean the cylinder is getting so much diesel injected in, it's blowing the flame out, then you get the raw diesel turning to smoke in the hot exhaust, and the nasty fuel smelling exhaust.
Dirtydmax86
Dirtydmax86
Jan 2, 2017
17
Sacramento ca
Gotcha. Makes lots of sense. Even more when i increased pressure using my snap on scanner.
