Y Bridge
MaxComp88B
152
15
So I am planning on buying a y bridge. I am not talking about deletes but my EGR has been deleted and the stock intake that is a square has everything turned off in it. If I put a new y bridge and round intake pipe to flow better and since it won't have all the stuff in it a stock one does will I get a check engine light? Everything right now is turned off with EFI Live but I still have stock y bridge and stuff. Will I need to retune it? Will the check engine light come back on? Also where can I find a good install of a y bridge and intake pipe?
Yngdmax92
962
the only thing that might break your chops is the intake air heater. if you didnt get it shut off the first time around. You might just need to update your tunes. that is all.
Reactions: MaxComp88B
BLACKMAX1
WAY2EVL
Jul 10, 2013
555
VA beach
If it got shut off the first go around then it wont throw a code correct?
Correct. For removal there Is a thread on here you can search for. I think it's called "LMM Duramax EGR Delete" goes over Y-bridge removal. Also tons of youtube videos on it. Some separate the bridge to get it out (what I did) some pull it out whole.
