Would bad head gaskets and etc affect injestor balance rates?
Dozerboy
4,811
393
TX of course
The machine shop call and told me my heads are good, but I have minor leaks in 5 of my pistons valve seats and an issue with a stem seal or 2. I had 1 injector with high rates and 1 on the edge. The rest where ok. I'm wondering if the issues with my heads and gaskets is what made my rates what they where.
Lbz with 190k with good compression before tearing it down.
Mikey52
115
29
Yes it's possible. The balance rates are to help balance power out put of all the cylinders among other things. If you have a weak cylinder the computer will add fuel to that cylinder or pull fuel from another cylinder to help balance the engine.
Dozerboy
4,811
393
TX of course
I found this piece of metal in the top of my head. While I was stripping it for the machine shop. Its sheared off of something. I couldn’t see anything obvious and the machine shop didn’t mention anything being broken yet. Ideas?
Dozerboy
4,811
393
TX of course
Looks kind of like a cam pin. Not sure how it would have gotten to the head though.
Sent from my 2PZC5 using Tapatalk
It's sheared off of something. You can't see in the picture, but it definitely broke off something longer.
Dozerboy
4,811
393
TX of course
I was cleaning up my pistons today and 1 or 2 had and different burn pattern. What would cause that an bad injector? Or from the blown HG?
Dozerboy
4,811
393
TX of course
Any have some input on why there is so much more carbon on the pistons in the top picture on the left hand side?
3,681
236
If I were to guess, that cylinder had less air available, resulting in a sootier burn. That could be due to lower valve lift, leaking head gasket, leaking rings, leaking valves, etc. It could also be poor fuel atomization from that injector.
I personally wouldn't worry about that too much, as it doesn't look that bad IMO. Especially since you know you had leaking valves & head gaskets, and are fixing those issues.
Dozerboy
4,811
393
TX of course
According to EFI Cylinder 3 and 8 was on the verge. I’m just not sure if EFI has the cylinders numbers right.
I don’t recall where the machine shop pointed out the HGs where leaking, but I had leaks on the valves on 2,3,4,5, and 6.
4,953
if it was wrong, it would be based on "firing order". So the cylinder 3rd in firing is Cyl 7 and cylinder on the 8th firing is Cyl 3.
Dozerboy
4,811
393
TX of course
I didn’t even think about that.
I thought EFI had fixed that discrepancy?
I don’t know. I know there are issues that have been ongoing for years. They don’t seem to have time or care to fix them. I’ve had issues with logs corresponding in the tunes for years. One of the guys on their forum even told them where the issue was. They never did anything about that I know of.
