Ok.. a few weeks ago I had my transfer case harness come unhooked from the clips and fall into the front drive shaft and get ripped apart and pulled the wiring and plug out if the tcase shift motor..see pics below. The service 4wd light came on as well as the abs and brake lights..
I got kinda lucky and it actually just unplugged the plugs up in the engine bay instead of destroying them. So I get another harness and motor... install them and 4wd works now.. shifts as it should but the abs and brake lights still come on but only showed a code once and it was a C0055. It will shift into gear and not be in limp mode but when I let off the brake and the truck moves.. I get about 30ft range inhibited flashes on the DIC. I can switch gears and it goes away.. let's the truck move again for a short distance then says range inhibited again. No codes.. I've also got a female plug I can't seem to find where it hooks. Has to be a speed sensor because it's purple and green twisted pair like the rest of the speed sensors.. here's the plug
Thanks in advance for any help
