Winter storage advice
Mainecobra
Sep 19, 2014
84
I have a built 2006 duramax that i just bought and will not be driving in the winter here in maine. It will be stored in my garage not heated for around 5 months. It gets very cold here. Just looking for advice on storage procedure. As in filling up fuel vs not. Adding additives to fuel to store it ect. Thanks guys
minisub
6-5/6-6;Whatever It Takes
Sep 11, 2006
474
Cleveland, OH
I park mine from Thanksgiving until Spring. Full tank with a double dose of additive is about all I do. I do roll it out on those rare sunny days we have here Cleveland every few weeks and let it run for a bit to move everything around. I also close the windows tight as I get a fair bit of condensation in that garage when the weather starts bouncing around a lot.
3,681
236
Throw some additive in the tank if you have summer fuel (or it will not start until the spring, no matter what you want), close the windows, and put it on a battery maintainer (you can disconnect the batteries too, but there is no need). If the garage might have rodents, put some bait out. I have found leaving the hood open discourages them from trying to nest in the engine bay as well (but then your engine gets dusty, so choose wisely!).
5 months of sitting won't hurt anything. The only potential issues are dead batteries, rodents, dust, and gelled fuel (if you need to start it when cold). Not hard to take care of :thumb:
To un-winterize it, I recommend changing the motor oil after the first or 2nd heat cycle on the motor. This is not strictly necessary, but it can get rid of any remaining moisture/whatever that doesn't boil out on the first drive. That, and give it a bath, I am always amazed how much dust accumulates in 5 months!
Janimal444
354
Salem, NH
I just add some fuel additive to my tank, but I do start it about once a week and let it idle for an hour or so. I'm not sure if that helps or not but that's what I've always done.
I do drive the truck a few times each winter though. Probably no more than 5.
DaveB
Sep 6, 2009
409
Northeast Indiana
The last three winters all I have done is fill it full of fuel, dump in a bottle of fuel additive, put it on a battery tender, put on my stock wheels/tires for it to sit on, and then put dryer sheets everywhere. Someone told me that trick and I've never had an issue with rodents.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Just drop it off at my house and I will take good care of it for you! :thumb:
You will need to leave the key's!
Mainecobra
Sep 19, 2014
84
Thanks guys this is such a great site. What do you guys recommend for additive? Stabil for diesels?
Mainecobra
Sep 19, 2014
84
Yea they use liquid salt up here in Maine so my beast stays in the garage for the winter and stays rust free. This liquid salt is deadly!!,
Mainecobra
Sep 19, 2014
84
Yea ill drop it off to you and you drop off like 60k cash to me!! My dad lives out in St. Paul had a friggen blast last time I was there in my college days. My dad gave me his credit card for the night and said "have a good time son"
I met some college girls at a bar woke up with one of them in her apartment have no clue how I found my way back to my dads place. Flew home and he called me and said WTF I have a $1200 liquor bill when u were here!! I must have went a little nuts ordering drinks for many!! Good times in MN��
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Bump. Any other tips or tricks? My truck will probably go away the first week in december. It will be in a heated garage. Thinking fuel treatment, up on jack stands with a battery tender. Anything else?
Porno Joe
507
South of Pittsburgh
I don't store my dmax but I've been storing 3 of my other summer only trucks, as well as bikes, for over 10 years. its a heated garage. Hell my dad has been storing his chevelle for probably 30 years, it might have some of the same old leaded gas in it still!
We don't do anything special to them other than put them on a battery tender. If I can I fill up the tank, but there are years I put them away with only a half tank. I never bother with jack stands. only storing for a few months has not had any ill effects on my tires. Might be a little bumpy first ride out, but nothing major.
When I pull them out in spring I check the air pressure and let them idle for probably 30 minutes. first drive is easy. never had a single issue related to sitting
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Truck got parked last night. I got it good and clean then wiped it down with detail spray. I have an LMC truck 4 layer cover coming. I have a battery tender Jr ordered and I have 4x dose of fuel treatment in a full tank. I'll probably throw some dryer sheets in it when I put the cover on just for good measure. Any other tips?
clrussell
pro-procrastinator
Sep 23, 2013
5,910
364
Drink beer while looking at it in that bad ass garage
DaveB
Sep 6, 2009
409
Northeast Indiana
All I've ever done is clean it up well, fill the tank and/or dump in a small bottle of the white diesel kleen, battery tender on it, and dryer sheets around it. I have always put my stock wheels on so I didn't worry about jack stands or anything. Its also never been a heated space. I've never had an issue.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
LMC cover arrived and I was very happy with the bang for the buck. I want to say it was about $180 shipped
4,955
Do any of you that let your rigs sit for 5+ months at a time without starting have any excess material in the oil filter after that first start up? ive always had a concern in the back of my head of dry oil starts from an engine sitting so long and oil migrating its way off the cyl walls and bearings. may just be paranoia though as ive not done much research on the subject. just having my motor sit for a month made oil pressure take time to finally come out my turbo oil feed (to the point i was pressing the remote start kill when i saw oil finally come out).
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have always been under the impression that the motor will be just as dry in one month as it will in five months so instead of starting it multiple times I will just wait and do it once when I am ready to bring it back out of storage.
Edit: If my thinking is wrong then by all means let me know.
