LB7: Why won't it start!?
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
http://www.duramaxdiesels.com/forum/showthread.php?t=14795&highlight=Start&page=2
They don't need fuel to crank but you need a min of 4000 to run most trucks idle at 6000 but it will idle at 4000 no problem .... You are right about injectors opening but if he has 1200 even 1500 it won't start and I would guess bad inj or cp3
Read post 67 there is a good document from GM in there and the whole thread is good for the OP
blackdirtymax
Apr 15, 2010
825
augusta, ga
Thanks buddy
Built motor , duel fuelers , 60's overs , gtx4202r
MaxPowerLB7
Amateur
Nov 8, 2007
623
Spanish Fork, UT
Like said, isolate injector banks and pumps if possible. Testing fuel return on injector banks and pump(s) as well. Both those tests are very time consuming though. It is possible to have air in the system from a cracked fuel line or hose, I've seen trucks run momentarily with a bad fuel hose. It would help a lot to see rail pressure and commanded fuel flow.
slipagnt
Sep 20, 2011
29
Marietta GA
thanks for the help guys. I'll start easy and double check cam and crank sensor operation. then proceed to verify rail pressure. would a bad fpr be an issue?
slipagnt
Sep 20, 2011
29
Marietta GA
Allright, Cam and Crank sensors check out. Now I'm leaning towards cp3 or fprv. Anyone know how to test the fprv?
slipagnt
Sep 20, 2011
29
Marietta GA
I agree. It's in the future but not if I need a new cp3 or something. I've got no rail pressure. As a last resort I took off a high pressure line and got barely a drip while cranking it. I'm in denial with the injector thing. They're brand freakin new.
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
Did the supply line and return get mixed up? This pic is correct.
slipagnt
Sep 20, 2011
29
Marietta GA
Yeah, it's hooked up just like that. I bought new hoses from GM when I built the motor cause the others were falling apart.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
You took it off at the cp3?
