LBZ: Whine after Duel Fuelers?
ScreaminDuramax
Sep 19, 2013
345
Torrance
I installed my PPE kit over the weekend, and now under load i'm getting a whining noise. Last night while test driving it happened at 3k rpm, this morning when I took it to work it happened around 2k under load. I cant replicate in neutral. Its very similar to the noise a stereo makes when improperly grounded. Im going to post a video from my phone, try to weed out the turbo and listed to the whine.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
My truck does the same thing and it irritates the hell out of me. I think there is interference in the wiring somewhere but no mater what I move I can not get rid of the whirring sound. Mine is 100% coming through the stereo
ScreaminDuramax
Sep 19, 2013
345
Torrance
Mine isn't coming through the stereo, mine is in the engine bay
ScreaminDuramax
Sep 19, 2013
345
Torrance
The noise wasn't there before I put the fuelers on. I guess it could be a coincidence. I replaced them when I built my motor.
only thing still factory is the tensioner
Slowmax
Build what others' won't
Aug 3, 2013
468
United States
Is it possible the Dual pumps' added more load to the pulley system and now a weak link is showing itself, since Trojan find's his noise through the stereo?
4,953
I lined it up by sight, is there a better way to do it?
a 1 foot metal ruler works well. put the end so ruler crosses the dual fueler pulley wheel at two points and see where it lands against the a/c compressor as well as the power steering. the ruler wont land perfectly on the a/c pulley if your going off the outer face of the fueler pulley but you just want the line the ruler creates to be parallel to the edge of the a/c pulley edge face. same with the power steering pulley. two rulers help a bit more for a visual.
that noise sounds like a pump whine though. if you unplug the regulator at idle, can you get the noise?
ScreaminDuramax
Sep 19, 2013
345
Torrance
Got it, that's what I was planning on doing, hopefully its off, that's an easy fix ...
