Where is everyone?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
So, anyone out there still folding? Just got my new rig set up for it.
i7-2600k
GTX570HD
Corsair 16GB Ram
Asus P67 Pro
Corsair H70 cooler
Cooler Master HAF case
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
My machine is pissing me off with problems with my cards.
I keep getting this "kernel mode display driver version 275.33 stopped working and recovered"
It does not recover it crashers to a Blue screen of death that only flashes so i cant read it.
Then I have to do a reboot to fix it.
So far i have not found how to fix it and changing nVidia drivers has not helped.
jmaz268
Lead from the Front
May 20, 2010
2,895
40
Springfield IL
My water cooler took a shit and leaked water all over both of my power supplies....was disgusted and havent evaluated the damage yet.
C.C.Reed
May 1, 2008
91
Win7 I guess?
Is Aero on or off? Turn it on.
http://www.mydigitallife.info/how-to-turn-on-and-enable-aero-in-windows-7-enable-aero-peek/
With the 560TIs, 266.66 added support and 285.62 is known to cause less lag than other drivers. So, I would use either of those and none of the ones in between.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
285.62 is a no go sill doing it and now it is more often this sux.
You pay for something to work and it craps on you and they do nothing to fix it.
next up i will be trying the GeForce 290.36 beta
I had the same problem. Its a voltage issue. Turn off the power management and it will stop doing that.
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
was good for a few days till I tried to do a lot on it then back to crashing.
GeForce 290.36 beta is in now.
PS: power management has been off since I built the computer.
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
Not sure what could be going on with your system. I was running 260.99 until a few days ago with no problems. I added a GT550 to the system and had to move up to 275.33 for it to be recognized. The issue I had was one of the 450s would drop down to 405mhz and the only way to get it back up was to reboot. The fix was to drop that one back to stock speed without overclocking. Running good for a couple of days now.
Have you tried different slots or anything to try and eliminate that? Are you overclocking?
