What size is the rear yoke in my lly? 1480? Or whatever the sizes are I'm not sure. I know it's a 11.5 AAM rear end. I need to buy a new rear yoke to stop the leak out of the pinion seal.
Ok thanks a ton, also when I initially replaced this seal on the current yoke there was a rubber sleeve on the actually yoke. Shouldn't it be straight metal?
Also what I just thought of is maybe it's leaking from the splines? When I replaced the seal I used black Rtv in the splines and not the white sealant that was originally in it, could this have something to do with it?
They just put that sealent on there to help slide it on im pretty sure. It doesn leak from the splines, I didn't put anything on there since It was just a pain in the ass to remove! Its a 2 piece seal, metal framed with rubber.
