What kind of fitting in exhaust manifold for drive pressure?
thunder550
1,176
Phoenix, AZ
It's 12' total from the fitting to the gauge. Even without the coil the run would be about 8 ft, so figure there's probably 4 ft in the coil itself. The line is copper the whole way.
pizza pig
I Like to Party
Feb 13, 2012
266
CT
the 1/8" copper plugs up super fast, never had luck with it, had to switch to 1/4 copper and then the 1/8 nylon worked fine from the filter to the gauge.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
I had the same problem. And after about 6 months my mechanical gauge sooted up. This is my setup now with a JGS filter:
thunder550
1,176
Phoenix, AZ
Ordered the filter today. Also found a 1/8 NPT x 1/4 OD brass compression fitting on Amazon so I don't have to pull and redrill/tap the manifold for a larger size, that was nice. Got 5' of 1/4" copper tubing on the way too. Thanks for the help everyone.
