Want to buy electrical connectors for custom harnesses.
heathgu
135
Sunshine Coast, QLD Australia
Basically i want to build custom harness to suit the duramax into nissan patrol conversion that i am doing. So i basically need all the connectors. The engines i use already come with engine harnesses, so i just need the remaining connectors for the ECM, TCM and throttle pedal, etc.
Anyone know if you can buy these, and from who.
Cheers Heath
Transmission Control Module (TCM) 80-Way Connector
Object Number: 1653286
Connector Part Information
* OEM: 13551663
* Service: --
* Description: 80-Way
C175 Engine Side to Transmission Side
Object Number: 655729 Size: CH
* OEM: 12186609
* Service: --
* Description: 20-Way F Micro-Pack 100 Series (GY)
Engine Control Module (ECM) - C1
Object Number: 1544242 Size: CH
Click here for detailed picture of above image.
* OEM: 15438366
* Service: 89046933
* Description: 96-Way F Sealed (BK)
Engine Control Module (ECM) - C2
Object Number: 1544260 Size: CH
* OEM: 15462694
* Service: 88988935
* Description: 58-Way F Sealed (BK)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
PPE or SoCalDiesel might be able to lend a hand in that area. I've always had trouble trying to get connectors themselves, so we start with complete harnesses. There are two harnesses you need (and must match, LLY+LLY, LB7+LB7, LBZ+LBZ): Engine top, and Fusebox harness. The fusebox harness feeds both ECM and TCM, feeds the Allison, and connects to the Engine Top. Either harness is about $700-800 new. Used? About 1/2.
