hello all,
new to the forum, I've been reading through other peoples headaches with this demonic sensor problem. checked out the pin diagrams for the ecm and what not. just trying to pinpoint this before I start throwing cash at it. I recently picked the truck up at an auction not running for a deal I literally could not pass up. I've wanted this truck for years now. well some body had gotten a little wild with "speaker wire" and main harness wires from the ECM that were rubbed raw. I have gone through everything from start to finish on that side of it replacing with factory colored and sealed wire.
well... now the truck is running and driving I keep getting the P2564 code, thinking ah its just a sensor I swapped it out. no fix. I can hear the vanes sweeping each time I clear the codes but they act like they aren't getting signal from the sensor. so after researching I found in the pin diagram that #20 is my wire "yellow". now after this long post my question is which of the three on the sensor pigtail is it? none of them ohm out nor match colors with it. I figured one is power one is ground one is signal, but none of them have power on them and im not getting any resistance back which leads me to believe I have a bad/broken wire somewhere. my train of thought is to figure out which wire does what, make my own pig tail into the ecm temporarily for them and see what happens.
can anyone shed some light on the 3 wire functions for the VVTS?
thanks in advance and sorry for the long post again guys ive crammed my scenario into one post to help with as much info as I can
