In previous threads I have stated that I thought I had a bent rod, well compression test proves other wise. What causing this is my number 8 cylinder. When I shut off the number 8 injector the vibration stays steady, almost like the I Hector isn't working I'm the first place and when it is shit off my blue haze is gone. Compression test is 375 cold and 400 warm, so the cylinder is holding pressure and the first bump it gets 200 psi, blow by is minimal as well. Could it be the injector tip is screwed up some how? At idle with the rail pressure maxed out it still doesn't blue smoke. Rev it up, truck starts to vibrate and acts like number 8 is missing, almost like its shut off. Any other help would be greatly apperciated
