Very Low oil pressure(4psi)
Dante2795
Took truck to track today. Made first pass without issues until I went to park, then truck popped up with low oil pressure(reading 9-10psi). But once I give it some throttle the light would go off and pressure would build up. Was a little low on oil so I put some in. Then went up to 14 at idle. Made another pass, pressure went up to 60 psi until about half way down the track, pop, blew smoke, and turbo blew. Now oil pressure is only reading 4psi. Any ideas? Drained oil and opened filter, no metal shavings.
3,681
236
When the turbo blew, did you cap the turbo oil line afterwards? If that is flowing too much oil, it could drop the oil pressure for the whole motor.
Ron Nielson
691
116
Berryton, KS
Maybe something here to help:
INFORMATION
Bulletin No.: 03-06-93-001D
Date: October 09, 2008
Subject:
Diagnostic Information on Turbocharger Malfunction Due to Lack of Engine Oil for LBZ, LB7, LLY or LMM Duramax(TM) Diesel Engine
Models:
2001-2009 Chevrolet Silverado
2003-2009 Chevrolet Kodiak C4500-C5500 Series
2006-2009 Chevrolet Express
2001-2009 GMC Sierra
2003-2009 GMC TopKick C4500-C5500 Series
2006-2009 GMC Savana
with 6.6L Duramax(TM) V8 Diesel Engine (VINs D, 1, 2, 6 RPOs LBZ, LB7, LLY, LMM)
Supercede:
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 03-06-93-001C (Section 06 - Engine/Propulsion System).
Notice: Before installing a new turbocharger, clean any debris or excessive oil from the charge air cooler and intake system in order to prevent damage to the new turbocharger or an engine overspeed condition.
Spun Camshaft Bearing
If a turbocharger performance concern is thought to be caused from a deficiency of engine oil, the camshaft bearing should be checked. The number 4 camshaft bearing bore feeds the turbocharger engine oil supply hose. If this camshaft bearing spins in the bore, the turbocharger will be deprived of engine oil. This will cause a performance concern with the turbocharger. Incorrect diagnosis of this condition will result in a repeat performance concern with the turbocharger.
Camshaft Bearing Inspection
If the turbocharger has to be replaced, perform the following procedure in order to verify the condition of the number 4 camshaft bearing before installing a new turbocharger.
1. Remove the turbocharger. Refer to Service Information (SI) procedures for Turbocharger Replacement.
2. Remove the turbocharger oil supply hose.
3. Visually inspect for correct alignment of the number 4 camshaft bearing oil hole (Refer to illustration callout 4) through the turbocharger oil supply hole in the block (Refer to illustration callout 1). The camshaft journal oil groove (Refer to illustration callout 3) should be visible through the camshaft bearing oil hole (Refer to illustration callout 4).
4. Turn the engine over by hand a 1/2 turn. The camshaft journal oil groove (Refer to illustration callout 3) should still be visible through the camshaft bearing oil hole (Refer to illustration callout 4) as the engine is turned.
5. If the camshaft bearing (Refer to illustration callout 2) has spun, the camshaft bearing oil hole (Refer to illustration callout 4) will either not be visible at all or it will be misaligned with the turbocharger oil supply hole during the inspection procedure. In the event of a spun camshaft bearing, the engine must be replaced.
Restricted Turbocharger Oil Supply Hose
If a lack of oil is suspected, the turbocharger oil supply hose should also be checked for damage. The turbocharger oil feed line is a high pressure plastic tube that is protected by a stainless steel braided covering. If it is twisted at all or bent too far during turbocharger removal, the plastic line may fold and kink. The kink may cause an oil flow restriction. If the plastic pipe does kink, it will not return back to its normal size and shape. The damage may not be obvious upon inspection because the braided steel covering will hide the deformity.
LB7 Turbocharger Replacement
During turbocharger removal on the 6.6L LB7 engine, the turbocharger oil feed line can be pulled directly away from the turbocharger body in a perpendicular fashion. Care must be taken to avoid excessive bending of the line.
LBZ, LLY or LMM Turbocharger Replacement
During repairs on the 6.6L LBZ, LLY or LMM engine, the EGR cooler does not allow enough perpendicular movement of the line to clear the turbocharger for removal. However, the line can be pushed straight forward of the turbocharger with less risk of kinking the line. Assistance may be required to keep the lines clear of the turbocharger during removal or installation.
Notice: Do not twist the turbocharger oil supply line. Twisting of the line will result in the collapse and deformation of the plastic line, restricting oil flow and causing turbocharger performance concerns.
