Van thermostat housing
Bdsankey
3,910
1,074
Neenah, Wisconsin
I wish I did. My price would be more than it costs at the local parts store or Rock Auto. PN 19258620 is the one you're after and what I currently have installed on my LLY.
CarolinaHD
969
NC
The van hose wont fit the lbz, you need Gates #23141 and trim a little off each end.
The angle of the radiator inlet is different between 01-05/06+
Bdsankey
3,910
1,074
Neenah, Wisconsin
The more you know. Guess I haven't tried it on a newer truck than an 01-05 as that is my most common market. Thanks for the info!
Nate’s Dmax
178
42
I used the GM van hose on my LBZ. Had to trim some off each end but worked great.
moparkxracer
2,309
33
Out and about
That’s the part I’m using on my lmm… it also clears PPE duel CP3 kit. You can also drill though one of the bolt holes on the top of the housing to get the coolant vent hole back.
