OK... it all seems to have worked out OK after all.
I'm going to fill in the blanks so maybe the next guy won't be left guessing which way is which, or wondering where the boot block & firmware update files can be found.
Maybe this will make it easier (from page 3 of "
Upgrading FlashScan.PDF"):
Upgrading the boot block and firmware of your FlashScan device:
The following steps, described in detail in the next few pages are required if you have an older Flashscan device that has not had any bootblock or firmware updates since it was new. If you have already performed any of these steps during previous beta updates you do not need to perform them again. Simply start from the first step that you have not performed yet.
A - If FlashScan has boot block
V2.04.xx or earlier, perform these steps:
1.
Program firmware V2.04.72 using the "EFILive Firmware Programmer"
...by pressing the button next to the red arrow to load the file "FSProg_V2_4_72.ffw" (which is in the "V7.5" folder) and then pressing the "Program" button.
2.
Upgrade the boot block to V2.05.08 using FlashScan’s menu option (Main Menu: F4 "Options" -> "F1 "Licensing" -> "F4 "Upgrade Bootblock")
3.
Program firmware V2.05.21 using the "EFILive Control Panel" in the "V8" folder. The Boot Block & Firmware update files (" *.efw") should be in the V8 folder too.
4. Follow the instructions in small red print (e.g.: "
Please update to version: 2.07.06" as shown above)
in the "EFILive Control Panel" and when you get done it should look like this:
